RCU Forums - View Single Post - Split elevator set up.
Old 01-20-2005 | 09:20 PM
RichD's Avatar
RichD
Default RE: Split elevator set up.
take a look at my servo set up... no, everything isnt tight, I am just getting things ready, using some servos laying around to do a test initial setup.
now looking at the picture, if I used a reversing servo Y, things will not work correctly.
My question is this....
do I NEED to beable to set individual trims for both servos in the radio, or can it easily be done mechanically? Reason for needing to know this is, the Futaba 7C will not individually trim 2 elevator servos, no matter how I try to mix them.
