how to cool the RCV engine
Do it the same way you would for any engine. Provide at least two times the amount of exit area as compared to entry area for cooling air to flow. Try to direct the flow of air over the engine. Sometimes it's necessary to create baffles inside the cowl.
It might help to mention if you're having a specific cooling problem, or if you're just puzzled as to how to go about it in the first place.
