RCU Forums - View Single Post - GP Sky Bolt is HERE!!!!
Old 01-21-2005 | 11:32 AM
JunkMan304
Default RE: GP Sky Bolt is HERE!!!!
Im at the point where I glue the two Bottom wings halves together. I attached the top wing which is already sheeted to the fuse and turned the plane upside down. I layed the two bottom halves together on the fuse and attached it to the top wing using the two "I" peices. As the bottom wing sits there the trailing edge does not touch in the center. The bottom wing is swept forward 1 degree. Did this happen to you? If I slide the I thing back some on the top wing it pushes the trailing edge of the bottom wing together but then it's real close to comming out.
