RCU Forums - View Single Post - Fixing a patch in a wing
Old 05-17-2002 | 11:30 AM
00hex
Default Fixing a patch in a wing
Try this: cut the piece almost all the way to each rib. If there are spars a little ways ahead and behind the patch cut the hole to those. Fold down any overlap that's left over and stick it down. You do NOT need CA! The covering has its own glue on it. If you CA it you will have a hard time getting it off if you need to patch it again!
If you just try to stick the patch on over the old covering, it will sag when you put the iron on it and you probably won't get it stuck down right.
BTW you will want to clean off all the oil before you try to stick any more covering down.
