RCU Forums - View Single Post - Fixing a patch in a wing
Old 05-17-2002 | 11:49 AM
00hex
Default Fixing a patch in a wing
The old covering. If the edges of the new piece of covering line up with ribs & spars the seam won't be as visible.
If the hole is small (less than about 2 in each way), you might be able to just put a new piece overtop. If hole is bigger it will most likely be too hard to get a new piece to look nice.
