RE: Cen MT2- NT-16 to 18 conversion results
The larger cooling head isn't needed. My max temp on a 90 degree day was 280 and that was running flat out for the hole tank.
The purple cooling head that is usually recomended is one of the option parts for the .16 if additional cooling is needed.
I would also recomend putting in a new piston pin. The added security is worth the 2.00 or 3.00 dollars
rolland
