RE: OS140 Troubles
G'day Andrew,
Sorry to hear you're having problems. I was hoping you'd be sorted, so you could sort out mine!! Cyclone is covered, wing bags made (thanks, mum) and first colour coat went on the fuz today. Amazing amount of work just to cover and finish a 2m model. So I hope to start installing gear on Oz day. Dallas is saying that he shortened his header by 15mm.
Did you install a shim?
Are you running low nitro?
That's will help me decide how much to hack off my header. If you went 8mm, I'll try starting with 5mm off.
See you at the field.
Regards,
sTeve
