RCU Forums - View Single Post - Reflex XTR vs. AFPD.. My Opinion....
Old 01-22-2005 | 06:47 PM
rusirius's Avatar
rusirius
Default RE: Reflex XTR vs. AFPD.. My Opinion....
Sorry guys... Just did get home from work... (weather event.. Okay, here's my settings for the AFPD raptor... This is the most realistic I can get it to fly in my opinion... It's pretty good...
Fuselage:
Weight: 2345 g
CG: 0cm 0cm 0cm
Frontal Drag: .30
Lateral Drag: .70
Lateral Lift: 1.1
Vertical Drag: .40
Vertical Lift: .9
Main Rotor:
Diameter: 124.5
Gear Ratio: 9.56
Blade Weight: 99.79g
Pitch min: -12
Pitch max: +12
Cyclic Pitch: 7
Tail Rotor:
Diameter: 24.4 cm
Gear Ratio: 4.1
Pitch min: -20
Pitch max: +20
Gyro Gain: 80
Gyro Zero Adjust: 35
Gyro Range: 40
Heading Hold: Yes
Piro Speed: 720 deg/s
Engine:
Max Power: .9 kW
Torque: 0%
Idle RPM: 2000RPM
Max RPM: 17000RPM
Weight: 335.66g
Right Thrust: 3 deg
Down Thrust: -2 deg
Here are my radio settings too. (I'm using a 9C, but shouldn't make any difference... If you only have three point curves, just use the top, bottom, and middle numbers.... if you have 7 points, just interpolate the middle figures...
Throttle Curves:
Normal: 30%, 45%, 56%, 70%, 83%
Idle-Up: 100%, 78%, 64%, 78%, 100% (I only use one idle-up on the sims)
Pitch Curves:
Normal: 23%, 44.5%, 63%, 78.5%, 88%
Idle-Up: 12%, 30%, 50%, 69%, 88%
Thr-Hold: 21%, 37.5%, 60%, 82%, 100%
Revo Mix off of course... Throttle Hold position at 0%
I generally use about 15% expo, but expo and dual-rates are for your preference...
