ORIGINAL: loupus
Thanks Bull for the terrific video clip and thanks Orcrest for the glowing report,
I have been considering one but had not seen one in the air until the video clip, or heard many reports on them (only about the landing gear) they certainly look nice in the air. I hope it wasn't your Barbie girl that took out your first Waco Bull??.
Is there anything special I need to be careful of while building the Waco, did you have any trouble setting up the connector rod for the Top and Bottom Ailerons?? If I get one and am pretty sure I will it will have a Magnum 75 2s in the front, should pull it easily and not have too much weight up front like you suggested Orcrest.
Thanks Guys.
Actually it was Barbie that took out my plane. I just epoxied her to the Balsa inside the cockpit. After time with the wind hitting her she tore loose the Balsa she was epoxied to and hit the rear stab / elivator and riped it right off the plane... Needless to say it didnt fly well with only half the stab & elivator...
Though I already ordered a new Barbie and new plane will be ready by spring....
