RCU Forums - View Single Post - Mystery Engine!!!!!
Old 01-22-2005 | 11:12 PM
tkg
Default RE: Mystery Engine!!!!!
That extra needle is the choke. When you rotate it, you will see it move in and out a bit. There should be a detent all the in and all the way out. Out is choke on and in is normal run.
Whit the choke in the normal needles will adjust OK.
