RE: Insight
Erik,
I do not intend to make drastic changes to the plans (lower belly, very slight changes to wing and stab position). I will be building another Insight using the updated plans and I expect it to fly as well or slightly better.... if it still requires a bit of mix, I will gladly share that information. The mix that I have, I can live with. Also, I have found the cause of the slight roll coupling and that is already ammended on the plans. I am going to speak with an aerodynamics friend today about this and other ideas for future designs.
I can certainly supply CAD files if you prefer.
-Mark
