RCU Forums - View Single Post - Refueling through pressure line
Old 01-23-2005 | 02:58 PM
pe reivers
Default RE: Refueling through pressure line
It is not a no-no, but I would rather use a third line, in which I permanently install a good filter. That way, the only foreign matter that enters the fuel tank can do so by the pressure line. I also use the third line to empty the tank.
Even so, The very fine mesh I use in the fuel line filter gets clogged after a while.
