RE: U-Can-Do 3d 46?
Hi all, I just picked up a used UCD 46 with a older YS 63 no radio gear..
I was planing on useing a APC13x4w, I've only looked at tower so far
but I see no W prop.. But did see the APC 13x4. Does APC make a W
on this size? I was planning on getting a spinner, but was looking at
the true turn 2" wide cut, will this prop cutout be to wide for the APC
13x4?? Also I was going to order some HS 425bb's (5) and the HS635
for the rudder and run on 6v.. Will these servo's be good enough?
Guess CG at 5&5/8" to 6" is a good starting point? Thanks for any
info...
