RCU Forums - View Single Post - Piper Cub 80" 6.5lb electric conversion HELP
Old 01-24-2005 | 02:06 PM
Greg Covey's Avatar
Greg Covey
Default RE: Piper Cub 80" 6.5lb electric conversion HELP
Hi Carl,
Typically, the stated weight on a glow-powered plane is dry (or without fuel) unless stated otherwise. You should add 8oz for a plane that size when the tank is full. The game-playing specsmanship can often be confusing.
A Cub design lends itself to require less power for flight. However, you should keep in mind that water take-offs will require more power than ground take-offs. This looks like your Hangar 9 80" Cub at Horizon Hobby [link=http://www.horizonhobby.com/Shop/ByCategory/Product/Default.aspx?ProdID=HAN1500]here[/link].
The Graupner 700 BB motor geared 2:1 looks like a good brushed candidate. With a flying weight of about 6lbs, your 500 watt geared Speed 700 motor will provide around 83w/lb which should work fine.
Good luck!
