RCU Forums - View Single Post - What clear coat will work?
Old 01-24-2005 | 04:15 PM
discusmike
Default RE: What clear coat will work?
One of the colors im using is the acyrlic enamel from dupli color,the others must not be,i had problems finding the correct colors i needed,so i had to mix and match to make everything work out the way i wanted.I think im going to go with the water based poly,thanks.
