RCU Forums - View Single Post - Tensor question
Old 01-24-2005 | 06:29 PM
3D ONdaEDGE
Default Tensor question
Hello everyone. I have a quick repair question. I built my tensor with a HIMAX 2812 outrunner. About the only way to mount it is to screw it to the rear of the plywood mountplate that comes with the kit and mount that out on the very end of the nose. In other words the mount is on the front of the motor versus on the rear of the AXI motors, Anyway, like I said the plate was mount way out on the very end of the nose of the plane. Well, I dumb thumbed and broke the nose off of it. Where the vertical and horizontal fuse glues together is all fine, it is just the extensions that stick out on each part. I have all the foam piesce that i can glue on there, but it was kind of weak before, and I dont know if I would trust it after repairing it. Is there a better way I can mount the motor like using contest grade balsa and carbon fiber cloth. I dont know if that would work but I am open for any suggestions that you may have. Thanks in advance.
