RCU Forums - View Single Post - thrust angle for h9 cap 232????
Old 01-24-2005 | 09:21 PM
johnfly
Default thrust angle for h9 cap 232????
just got a used h9 cap 232 ..... 73" wingspan, 1.20 size.... but the previous owner kept the motor. I have a saito 1.5 wanting a home and the two seem made for each other.... so i proped up the tail until the wing incidence was 0 then checked the horizontal stab...yep its 0....... set the thrust angle to 0.....then i put the cowl on and the backplate for the spinner was a good three eights of an inch above the spinner.... should i just align the spinner to the cowl or more specifically how many degrees downthrust should it have??? I called horizon and the guy said..........."aaaaaaaaaaaaaa well ya that sounds pretty close........pause ......... ya probably anywhere between 1 and 3 deg......." WOW thks for the hlp....sorry to bother u...............
does anyone know what it shoul be???????
thanks. JB.
