Hi David,
ORIGINAL: David Gibbs
The one I can't construct a mental picture of is the interaction between rudder and wing dihedral - in flat flight but also in knife-edge. I gather the rudder hinge line plays an important role on drag when the rudder is deflected -- and hence the angle of the hinge line and the portion above versus below the stab impacts pull towards belly or canopy in knifeedge, in addition to the combination of thrust line and wing/stab incidences. The centre of lift must have something to do with the aerodynamics of the fuz on its side (which I assume could be quite different to the wing in horizontal flight, and quite different across the thinner models of 5+ years back and the bulkier ones today). But what are the dynamics of the interaction between the rudder and dihedral that lead to adverse and proverse roll on rudder? Any ideas (or a full, simple explanation!!) appreciated.
there is a perfect explanation with animation for you:
http://142.26.194.131/aerodynamics1/...ity/Page5.html
and there is another good source:
http://www.centennialofflight.gov/es...ty_II/TH27.htm
What do you think guys about flying horizontal stabilizer (stabilator) on pattern planes? It can be easily balanced statically and aerodinamically too - your servo will longer lasting!
