GP Giles G202 Problem
Hi again 2lo. The plane doesn't seem to do anything else strange. It doesn't do a tight loop on 1/2 elevator. I'm wondering if I didn't do the lateral balancing correctly though. Any tips on how to do this properly?
I used some twine and hung the plane from the prop shaft as well as the fuse just in front of the stabilizer. Should I use thinner string (like fishing line)? Should I hang the rear string somewhere other than in front of the stab? Like the tail gear wire? I was afraid i'd snap the tail gear off.
It seemed to me I could make it tip either way just by nudging it one way or another.
Thanks again!
chris
