RCU Forums - View Single Post - Vectorflight Edge 540 build
Old 01-25-2005 | 09:09 PM
  #464
rcjon
Default RE: Vectorflight Edge 540 build
>> Jon, has your Edge come yet? Guess not, or you would have said something.<<
They said it was in the USPS on Friday and expect delivery in 2-3 business days. I don't expect it before Friday or even next week. It has been my experience that big packages in the USPS take a long time.
>>Not sure if I am going to go with hinge points or CA hinges. I can't see myself putting this plane through any more radical stuff than I put my Funtana through and the CA hinges seem to be working and holding up well on that plane. Is it for extra strength that you went with hinge points or for some other reasons. Are the hinge points you are using the plastic or the metal ones? Thanks.<<
I got the plastic ones with a metal hinge. No particular reason as CA hinges seem to work ok if you get them glued properly. I have been told that they wear out and break off, but I haven't flown anything that long. I just wanted to try the hinge points this time. I'm also going to try Gorilla glue.
