RCU Forums - View Single Post - Steering problems during take off.
Old 09-05-2002 | 12:48 PM
troyp
Default Steering problems during take off.
I seem to still be having problems trying to control my plane whilst attempting some practice take off runs. I have moved the control rod so it was closer in on the servo arm to reduce the travel of the front wheel when turning. But once I build up some speed the plane starts to weave from the left to the right as I try to keep it straight.
A mate of mine first noticed a problem that one wheel could turn more freely than the other so we freed up the other wheel but it didnt seem to fix the problem. The plane will pull slightly to the left but when I try to correct it, it seems to then want to pull to the right.
It seems as if the steering is less responsive since I moved the control rod closer on the servo arm and so takes longer to correct itself when I apply opposite stick. But if I move it back then it is to sensitive. Do I sounbd confused??? Thats cause I am.
Does anyone have any suggestions for this?
Troy.
