Steering problems during take off.
If you are flying from a grass field, you will always have a little drift, due to the blades of grass hitting the wheels. When you correct a drift just give a little stick in the opposite direction, as soon as you see a hint of it going the other way, neutralize the stick. Do not run it any farther on the ground than needed to lift off. The faster it gets on the ground, the worse the drift will be.
