RCU Forums - View Single Post - Problems with servos
Old 09-05-2002 | 10:42 PM
EXCAP232
My Feedback: (12)
Default Re: Problems with servos
Originally posted by troyp
I have two problems with my servos. The first one is that my rudder/steer wheel servo seems to have a constant hum coming from it especially after moving the controls. If I move the servo arm manually slightly it will stop the hum. Will this effect anything such as battery drain etc? The other problem is that when I move my rudder the elevator will also move slightly. I do not think that it has anything to do with the control rods touching as far as I can see anyway and I thought it was as if the servos were picking up the signal from the other servo. Can this happen and can it be fixed?
Thanks again,
Troy.
What you are hearing is the servo straining to move to the postion dictated by the receiver. Disconnect the servo arm and check how much pressure is required to move the surface. There probably is a bind in the control linkage. Once eliminated the hum will generally go away. This condition can cause excessive battery drain and eventually a crash. Check this before flying!
As far as the cross controlling make sure you aren't moving the stick in more than one direction. There should be no crossover of controls.
EXCAP232
