RCU Forums - View Single Post - Ignition Switches
Old 01-26-2005 | 09:49 PM
R/C Lee
Default Ignition Switches
I'll be using two G-38's in a new B-25 and want to have both a manual ignition cutoff as well as a transmitter-controlled cutoff. Since the engines have magnetos, for the transmitter-controlled cutoff I was thinking of a servo to switch, using a pushrod to actuate the switch. I'm sure some of you have already solved this problem, and I'd appreciate your input on how to accomplish this and what switch to use. Thanks, Lee
