RE: Unable to run AeroFly Pro Deluxe
Even if Crowfly is wrong and the TNT2 does support OpenGL, I would say the card is not powerful enough to run Aerofly. If that card is stock in your system, I would guess your machine is 4 to 5 years old maybe?? If so, it should be AGP. 4X or 2X, I don't know, but you should be able to replace it with a GForce 4 Ti for 60 bucks or so and if your processor is fast enough, it should work. A little more info about your system would help: manufacturer, age, cpu speed, RAM, OS. Is this your first power-hungry program you have ran or do you play current games like Battlefield or Doom3? My thoughts are that if that is the original card for your machine and you bought it that way, not built it yourself, you need some new hardware. My 2 cents.
