RE: O.S max 46la engine problems
if it starts ok &runs through part of the tank until it begins to show problems , its a fuel feed/tank problem. either the tank may have settled into too low position or you have hole in the feed line inside the tank.its causing it to run a bit too lean , lose power &heat up.
