RCU Forums - View Single Post - bomb release
Thread: bomb release
Old 01-27-2005 | 01:32 AM
ELTIGRE
Default RE: bomb release
i have done this on several planes & its easy. the last little bit of throttle TRIM movement pulls the wire releasing the bomb. if you set up with high trim or close to it it'll work fine. what wont be so easy is finding the bomb after you drop it . you can't watch the bomb and your plane at the same time .if its off field good luck-- from one who lost two bright orange vortac bombs.!!!
