RCU Forums - View Single Post - exponential settings??
Old 01-27-2005 | 01:30 PM
tanasit
Default RE: exponential settings??
Exponential will either make the sensitivity around the mid stick more or less sensitive. In your case of overcorrection, you will need to lessen the sensitivity and Futaba will assigh the minus sign for this. The easiest way is to set it while holding the AIL or ELE stick off center, enter the number and make sure that the movement of the swash plate become "less" and not MORE, so you will get what you want.
ORIGINAL: clovus
Howdy,
The more threads I read the more I hear - LITTLE control stick movements to help smooth out your hovering. With this in mind I have noticed that I still tend to overcorrect ...ending in some interesting moments. Will dailing in some exponential help reduce this? Any ideas on how much exponential and on what channels? I had a look on my controller and it has the option but I am unsure if it should be - or +ve.
thanx.
