RCU Forums - View Single Post - problem with steering on the ground
Old 01-27-2005 | 04:51 PM
jlobster88
Default problem with steering on the ground
I had a thunder tiger trainer .25, i crashed it and repaired it (made it into a taildragger), and flew it again and decided to retire it from flying, but now that there is 3+ft of snow i decided to run it around. i put the skis on and went outside. The plane turns to the right, even if i give it full left rudder. I know that the counterclockwise rotation of the prop is causing this, but is there anyway to make it so that I can turn left?
