RCU Forums - View Single Post - Which Engine?
Old 01-27-2005 | 06:49 PM
Frost_'s Avatar
Frost_
Default RE: Which Engine?
ORIGINAL: TEAM A
Is the epic better out of the box than the OS?
i too am runnig with the steel spur but was in doubt that a bigger than 18t clutch bel would fit in corectly
i dont want to change the sput if the clutch bel fits
If i get the titanium top shaft and steel idler will the bottom last gear in the trans shread?
thanks.
Out of the box the OS is a tad stronger... they are REALLY close in the real world. From a mod. standpoint the Epic has more to work by far, so there is REAL potential there.
As far as fit, I have no idea, I haven't tried it. The worst case scenario is that you have to make the slots for the mount longer on the front side to let it slide further.
That "bottom last gear" is the diff. Like I said, I had an alloy one, but I put it on a brand new diff. I decided to leave the stock diff in until it dies. It has held up just fine so far though. The ported Epic running 30% Race broke the titanium top-shaft a week or so ago...
