RCU Forums - View Single Post - Sig Hog Bipe Build
Old 01-27-2005 | 07:43 PM
  #44
hookedonrc's Avatar
hookedonrc
Default RE: Sig Hog Bipe Build
Day 8:
Well I am not happy and am trying to decide what to do. Today, I decided to reinforce the TE sheeting on the top wing. Since the CA has been bothering me quite a bit, I decided to use titebond glue. You can see from the pics that it did not go well. For all but 3 bays on the left side all was OK. However, on the middle bays, the TE sheeting had become so thin from sanding that it was pretty thin. When I glued the 1/16" sheeting on the back side, it warped quite a bit. I am now trying to figure out what to do. I have considered filling the warped area with Hobbylite filler than sanding smooth. And have even thoguht about taking out the sheeting between the ribs, building side supports and refilling with 1/16" sheeting. I am just not in a mood to make the decision yet, so I have pushed in some clothespins to try to keep the surface as flat as possible and once the glue dries, I will think about my next move. Btw, the pictures really don't show the dips in the sheeting very well.
Ideas on what to do are welcome and will be appreciated!!!
ID:	221452   Click image for larger version
