I don't know the type of motor on the plane. If you can let me know that, the gear ratio and the prop that will go on it, I can give you a much better answer.
If it's a 300 type motor, it's possible the 10 amp will be at it's limit in high throttle situations. In that case, you'd be better off with the 15 amp ESC.
