RCU Forums - View Single Post - Help breaking in a FA82A Satio engine!
Old 01-27-2005 | 10:55 PM
Victor Adams
Default RE: Help breaking in a FA82A Satio engine!
Thank you Sir
I DID AS YOU SAID and Started with the 13x6 prop and the 15% Omega fuel.it started wright up with no problems and i set the idle at 4000 rpm. and ran three tanks thrue it then i adjusted the high to where it was doing approx. 9500rpm.It sound good even with the low speed set at the factory setting it still responds very quick.I think i will take it for a flight tommorrow if i get off in time.I read the manual about setting the low speed but can you give me a few extra tips.You know where thay say to set a two stroke by sound well from wourking 25 years in the rental natural gas compression business i have trouble hearing the diffrence in the sounds i guess it from wourking on a lot of Ajax and Cat natural gas engines.That a good one i can keep engines running that cost several million of dollars but have trouble with a $200.00 one.Go figure.
I really do thank you for your help.
Vic.
