RCU Forums - View Single Post - Zenoah G62 problem
Old 01-28-2005 | 12:29 AM
tkg
Default RE: Zenoah G62 problem
Remove the carb, with the throttle closed hold it up to a light. You should not see any light, any light you see is an air leak.
DID you remove the throttle spring??? If so you probably have beat up the edges of the buterfly and that where the leak is.
