RE: spur play
You should have SOME play in it. Millimeters shounds like its normal. Mine goes back and forth, this is the spur engaging and disengaging foward. The tighter you crank it down, the less play. To tighten the spur, crank it down all the way, and then back off 1/8 of a turn.
