Removing Glued Platform
Hello Everyone,
I started a CG Eagle II approximately seven years ago. I put it aside. I would now like to finish it this Winter and learn to fly it this Spring.
The problem I have at the moment is that I installed the Horizontal Stabilizer Support Platform and it ended up drying in a cocked attitude. My question is, if you could be so kind, How would you go about removing the Platform with as little damage to the wood as possible ? The Platform was glued in with original Tite Bond.
Installing the tail feathers seems to be the only thing that has been gnawing at my side in finishing the kit and any help in a possible solution will be Greatly Appreciated.
Thank You Ever So Kindly,
waynerr
