ORIGINAL: bryris
They never buzz when centered. Only when flanked, and even then it is few and far between.
Then that is pretty normal, the servo is just working against the load of the surface.
A consistent buzzing with the servo at center or at any point in it's travel is almost always friction and most likely occurs when the pushrod is either in a tube or making a slight or even not so slight curve or bend along it's length. It is also possible that the throw is set a little bit to much on the servo and the control surface is running out of throw before the servo gets to it's end point (flanked)
Montague has a great idea on checking...
