RCU Forums - View Single Post - Impact
Thread: Impact
Old 01-28-2005 | 02:49 PM
MTK
Default RE: Impact
I am a strong proponent of building a new tail components for the Impact and have written about this before. The stock parts are much too heavy. Good job!
MattK
ORIGINAL: ERichard
ORIGINAL: David Gibbs
I am just starting builidng a second one (cos I really like how they fly), and am going to replace the provided rudder with a foam/balsa sheeted one, put in a new tail post extending past the back of fuz, bevel the edges of both, and hinge it the proven way (I tend to use Hayes hinges) where there is as little as possible scope for movement. I guess the counterbalance will need to be carved from balsa -- and given it is the Impact scheme I may need to do some paint matching and air brushing! Other than the painting it should be very straightforward.
I may also (once I am set up to do it the way above) have a go at trimming the front of the provided rudder (the round, glass section at the hinge line) and replacing it with a balsa leading edge as suggested above -- it is good idea, but I would like to compare relative weights.
Hi Guys,
I too didn't like the rudder for the Impact. My stock rudder straight out of the box was 82 grams! (and that is without all the hinges and post). I decided to experiment with building an all balsa one and just bevel the hinge line and use CA hinges, then seal the gap. It is still a work in progress but here are some of pictures of what I've got so far.
So far I have saved about an ounce (the all balsa rudder is 54 grams...before shaping and beveling). Based on several other Impacts I've seen in the area, I decided to move the rudder pull-pull horn above the stab, a position that allows for straighter and more convenient rudder servo installation.
Anybody else have any weights for their redone rudders?
-Erik
