I'd set my throws for high rate and then simply assign a percentage to low rate......I set up each rate according to the instructions for the plane....I'm assuming I need'nt mess with the percentages then.
Well, sometimes the instructions for a plane will suggest both high and low "throws". Say, 1/2" up and down for the elevator as high throws, and 3/8" up and down for low.
In this case you'd set the throws at 1/2" while on high rate in the transmitter, then put in maybe 70% once you went to low rates in the programming. Then, when you hit the low rate switch for elevator on top of the transmitter you'd get less travel on the elevators. (Does that make sense?)
Dennis-
