RE: Removing Glued Platform
If you have to use a saw to cut something, don't use a hacksaw blade. The kerf will be much, much too large. Use the razor saw as described above. You may or may not have to remove the backbone...depends upon how/where you cut. Xacto makes a small saw that will fit into their larger handle.
