RCU Forums - View Single Post - Vectorflight Edge 540 build
Old 01-28-2005 | 09:16 PM
  #571
ckangaroo70's Avatar
ckangaroo70
My Feedback: (51)
Default RE: Vectorflight Edge 540 build
ORIGINAL: rcjon
Luke,
Didn't you have a Saito 100 mounted sideways on your plane? It looks like I'm going to have a problem routing the throttle linkage around the fuel tank.
jon
Jon
Luke has the Saito 120, and he had his mounted inverted. My Plane has the Saito 100, and it is mouted sideways. I had no trouble with the throttle, but I did mine differnt than alot of others. The Manual suggest that you relocate the throttle servo up near the tank and on the side. I mounted my throttle servo right inline with the Rudder and Elevator Servos. This allowed the linkage to come in at a little better angle, and then I just made two Z bends that make the linkage run over top of the wing joiner, and then back down to the servo. It was a pretty simple thing to do, and besides I just couldn't see not using that nice spot that is allready cut out for the throttle servo.
