RCU Forums - View Single Post - Fury Setup
Thread: Fury Setup
Old 09-06-2002 | 07:38 PM
Furyflyer2's Avatar
Furyflyer2
My Feedback: (117)
Default Re: Fury Setup
Originally posted by JimmyA
I am setting up my new Fury 60 on my Futaba 9CHP. I am using swash SR3 and reveresed the elev. servo. All ATV are 100% and no subtrims used. the swash leveled pretty good and it seams to stay level after collective changes. Is there anything more I need to do to it as far as checking the throws on it? any other mixes? This is my First CCPM heli and I did not build it! All my other helis are mechanical mixing. Thanks for any tips.
Jimmy
Just make sure the swashplate moves level. You can do this by,
holding the flybar and move the collective.Watch the paddles they should not move, do this for both elevator and aileron. If you do see movement you will need to add some mixing til it's eliminated. I'm using 3-5% mixing in the up side of the elevator and nothing else.
