RE: Help breaking in a FA82A Satio engine!
Vic the factory low end settings are way rich. It is possible yours is three turns to rich. If it will idle good and transfer good you should be fine. If it stumbles during a fast transfer richen it up until it dosn't. Also did you adjust the valves? The suplied feeler gauge should drag slightly when set correctly. When my Saitos valves get out of adjustment it seems to effect the low end and transfer first.
David
