RCU Forums - View Single Post - sand in engine
Old 01-29-2005 | 05:49 PM
Nitro Rustler Racer's Avatar
Nitro Rustler Racer
Default RE: sand in engine
ORIGINAL: killer89
ORIGINAL: traxxarrus
yea it still runs but it cuts off after about 3 minutes. I am not sure how to take everything apart because i am just a beginner. Thanks for the help.
Its done... once the engine loses compression from the sanding of the piston and sleeve, it will only run while cold. This is because when cold the sleeve has not yet expanded and it runs with compression. Then once the sleeve expands the clearance is very loose and there is no compression when hot... same with a used motor.... I would not suggest trying to rebuild or pinch the sleeve because the crank is now scored and won't seal with the case, the bearing are probably very gritty aand shot and the p/s is worn... You can have it pinched, but then you'll have bearing and crank problems....
good luck...
r
if there was wasnt compression when the engine is hot then how does the engine run then?it has compression, but not as much as it was when the engine was cold
