RCU Forums - View Single Post - mousse can causing spitting carb
Old 01-29-2005 | 07:13 PM
Big Mike
Default RE: mousse can causing spitting carb
The MCP outlet (stinger) is 9/32" which is a little bigger than most use on their cans. I'm pretty sure the problem is excessive pressure in the fuel tank and I even thought about putting a pressure relief valve in the form of a one way valve tee'd off the tank vent with a fine tuned spring in the valve.
The only other thing I can think of as the cause for this spitting would be that the can is somehow sending a "Bad" wave back up through the enigne's intake system. This could be maybe remedied by tuning the can differently as suggested by Jim (thanks, Jim).
Big Mike
