RCU Forums - View Single Post - cheap and tough plane to learn on?
Old 01-29-2005 | 11:29 PM
flyinazn10
Default RE: cheap and tough plane to learn on?
thanks for the suggestion, after looking at at, im jus worried about the weight. my motor gets around 15 ounces of thrust, i might be able to make it 17, so if my plane ends up around 15 ounces, then ill need close to full throttle to hover, which would likely be a problem. if it was more around 10-12 oz maybe 13 ouces then ill jump to it but 15 is a little too much.
