RCU Forums - View Single Post - Onboard electric starting
Old 01-30-2005 | 10:53 AM
powerchute50
Default RE: Onboard electric starting
Thanks for the link info. On the Hobby Lobby unit I assume there is an over running clutch or dog setup in the gear reducer unit on the motor itself? The gas engine end of the drive shaft ends in a small gear that looks to be permanently running against the bigger gear on the prop hub. The over running clutch setup is the part I am interested in. Has anyone actually seen one of these units? How does this clutch work?
Don
