RCU Forums - View Single Post - Engine con rod rubbing
Old 01-30-2005 | 06:23 PM
ZAGNUT's Avatar
ZAGNUT
Default RE: Engine con rod rubbing
not much you can do....the rod is either going to rub up against the crank or back against the backplate depending on the engine and it's tolerances.
only real fix is to anodize or nickel plate the backplate to cancel out the wear you get when aluminium rubs against aluminium. the particles from this wear have been a long time suspect in premature plug death
dave
