RE: wildhare hinge glue?
I've used the Pro Bond Ultimate polyurethane, but not the Gorilla yet. I like the way the urethanes surround the hinge and ooze back a little, letting you know that the hinge point is surrounded.
Just keep some acetone on hand for cleaning as you go along. Also check the hinges as the glue is drying so you can clean up any that oozes out of the hole. The stuff holds just great!
