RE: futaba 7c question
Carlos,
In what channels to you have the flaps plugged into?
I found in setting up some mixes on the ailerons that if you had the second one plugged into channel 5 it wouldnt work correctly. For normal aileron usage it was fine but it wouldnt respond on mixes.
Where are you flying in Santiago? I used to live in the comuna of Huechuraba and I flew out by the airport.
